Reply
Re: Will a Huawei P20 Pro phone work for a 3G plan with Public Mobile network?
The Chinese version of the Huawei P20 Pro Dual SIM TD-LTE, the CLT-TL01, appears to support most of the frequencies that Public Mobile needs. https://www.frequencycheck.com/models/GlV4W/huawei-p20-pro-dual-sim-td-lte-clt-tl01-64gb-huawei-char...
Thanks to all who helped. My phone works with PM network.
You can check compatibility on the main page. Go to the top right corner, click get started. Then scroll down and check compatibility.
Good to know! I'm looking at a P40 via wish dot com.
Everything seems compatible.  Appreciate you asking the question!
Cheers, Greg
Yes I confirm Huawei P20 Pro works fine with Public Mobile.
Tags (1)
