10-08-2021 09:02 AM - edited 01-06-2022 03:43 AM
I don't know what GSM and CDMA mean. Will it work on Public Mobile? I'm really after this phone for the camera. My old Canon point and shoot died and I've looked at reviews for this phone's camera and video and it does a better job than my old dedicated camera. I figured might as well go for a phone with a good camera and carry one less thing in my pocket.
10-09-2021 06:53 AM
Yea it sure will. All Google phones have been unlocked for quite sometime for all carriers.
10-08-2021 10:24 AM - edited 10-09-2021 03:56 PM
Lol....compliments will get you everywhere.....😃!! Don't make me blush?!!😋
10-08-2021 10:19 AM
@Nothappy123 Yes, Google Pixel 3 works beautifully on PM. Also, the added bonus to getting this phone is that you will have support from @darlicious should you encounter any issue... She is great and helpful 🙂
10-08-2021 10:15 AM - edited 10-08-2021 10:18 AM
Here are the camera specs...
MAIN CAMERA
Single | 12.2 MP, f/1.8, 28mm (wide), 1/2.55", 1.4µm, dual pixel PDAF, OIS |
Features | Dual-LED flash, Pixel Shift, Auto-HDR, panorama |
Video | 4K@30fps, 1080p@30/60/120fps, 1080p@30fps (gyro-EIS) |
SELFIE CAMERA
Dual | 8 MP, f/1.8, 28mm (wide), PDAF 8 MP, f/2.2, 19mm (ultrawide), no AF |
Features | Auto-HDR |
Video | 1080p@30fps |
You can compare cameras as well on gsm arena....
https://www.gsmarena.com/google_pixel_3-9256.php
Edit:
I had a d'oh moment in this thread but if it helps.....🤔
10-08-2021 10:07 AM
I haven't shot a lot of video (not a fan) but yes pretty much it retains good sharpness in focus and colour.
10-08-2021 10:06 AM
Interesting that you mention astrophotography. I have a Zhumell 130 and a phone holder I'm itching to use. The Moto was ok but not enough pixels in video mode for good stacking images.(something I've yet to do) Can you extract single frames from the Pixel 3 video? I guess I should just google it. Need to find out the video file format. Thanks for your help.
10-08-2021 10:01 AM
Thanks! My Moto E4 is a Verizon and it seems ok.
What is the video like on the pixel 3? Same good low light performance?
10-08-2021 10:01 AM
Lol that's why I call it my camera! I have the other two phones to use....
The astrophotography will use an exposure usually between 30 sec and 1 min. Best with a mini tripod but I have propped up the phone to use it as well with some interesting results....
10-08-2021 09:54 AM
The low light performance is what caught my attention. And RAW files. and 4k video. Quite a step up from my dead Canon. I have a Nikon DSLR for "serious" work. But it won't fit in my pocket. Lol.
10-08-2021 09:53 AM
yeah... but in black
10-08-2021 09:51 AM
@darlicious wrote:I add photos from my camera as well, halfway thru the thread.
Pictures provided by @darlicious, particularly night shoots are amazingly good! Usually in classic camera you would need exposure of few seconds but with her camera it is 1/8 or 1/11 sec.
10-08-2021 09:43 AM - edited 10-08-2021 09:54 AM
Is it this one ?
If it's the Verizon variant make sure you remove the Verizon sim card before powering it on with no sim card inserted. If it has sufficient power go to>>Settings>>About phone>>Build number. Tap on the build number 7 times in quick succession to open the developers options. Scroll down to the OEM and turn it on.
You can then exit this area and insert your pm sim card to start the set up of your new phone. Turning the OEM on gives you the choice in future if you want to use the bootloader to continue to get updates beyond Android12 for example.
10-08-2021 09:37 AM
You can compare photo quality (up to the community's limited upload size) in this thread.....just skip the minor skirmish of lounge worthiness at the beginning of the thread.....I add photos from my camera as well, halfway thru the thread.
https://productioncommunity.publicmobile.ca/t5/The-Lounge/Phone-Camera-Action/td-p/704544
10-08-2021 09:36 AM
Thanks for the pic! I have the smallest one in the pic.
10-08-2021 09:33 AM - edited 10-08-2021 09:34 AM
Most likely not.....you need the smallest size. See below. Edit: Yes you are good to go...
10-08-2021 09:32 AM
@Nothappy123 Yes, Google Pixel 3 will work here without issue.
Both Moto E4 and Google take nano sim so you are good.
10-08-2021 09:26 AM - edited 10-08-2021 09:30 AM
It's a Moto E4 The sim is pretty small. It's 1/2" x 3/8"
I googled it... the E4 takes a nano sim. I guess that means I'm good to go?
10-08-2021 09:23 AM
Amazon ca has them. I'm not tech savvy enough to know what your post means. Would I need a new sim? I'd order it at the same time I ordered the phone if I need one.
10-08-2021 09:20 AM - edited 10-08-2021 09:39 AM
That phone will work perfectly fine with public mobile as that's my new camera. It does currently have a pm sim card in it from my extra data account that I had to reactivate this month. Are you purchasing from a Canadian retailer or American?
Edit:
It takes the nano sim size. Is your sim card a tric-cut? Can you snap it out the micro size frame? ( Not now of course!😃)
10-08-2021 09:15 AM
That's great! Will my current Public Mobile sim card in my old phone swap over or do I need a new sim card?
10-08-2021 09:09 AM
@Nothappy123 wrote:I don't know what GSM and CDMA mean. Will it work on Public Mobile? I'm really after this phone for the camera. My old cannon point and shoot died and I've looked at reviews for this phone's camera and video and it does a better job than my old dedicated camera. I figured might as well go for a phone with a good camera and carry one less thing in my pocket.
You can check for full specs here:
Google Pixel 3 - Full phone specifications (gsmarena.com)
The phone meets all PM requirements.
10-08-2021 09:05 AM - edited 10-08-2021 09:06 AM
This phone will work on the Public Mobile service. All google phones will work.
