Will OnePlus 8 work on Public Mobile in Nova Scotia?
PublicHouse
Hi,
Will the OnePlus 8 function on Nova Scotia's cellular network? It is 5G so I am concerned it might not work here.
Thanks
Staliger
@PublicHouse There are no issues with the phone and frequency for PM usage. You are good to go.
gblackma
Yes it will @PublicHouse according to this site https://www.gsmarena.com/oneplus_8_pro-9919.php its got the required 3g and 4g LTE bands.  Make sure its unlocked. Stay safe.
And if you haven't activated yet. Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Hi @PublicHouse ,
Yes
See previous post:
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/OnePlus-8-compatibility-with-PM/m-p/5...
Public Mobile:
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
OnePlus 8:
NETWORK
TechnologyGSM / CDMA / HSPA / LTE / 5G
2G bandsGSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
 CDMA 800 / 1900 & TD-SCDMA
3G bandsHSDPA 800 / 850 / 900 / 1700(AWS) / 1800 / 1900 / 2100
4G bands1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 25, 26, 28, 32, 34, 38, 39, 40, 41, 42, 46, 66 - EU
 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 25, 26, 28, 29, 30, 34, 38, 39, 40, 41, 46, 48, 66, 71 - NA
 1, 2, 3, 4, 5, 7, 8, 12, 17, 18, 19, 20, 26, 34, 38, 39, 40, 41, 46 - IN
 1, 2, 3, 4, 5, 7, 8, 12, 17, 18, 19, 20, 26, 34, 38, 39, 40, 41 - CN
5G bands1, 3, 7, 28, 78 SA/NSA - EU
 2, 5, 41, 66, 71 SA/NSA - NA
 41, 78, 79 SA/NSA - CN
 78 SA/NSA - IN
SpeedHSPA 42.2/5.76 Mbps, LTE-A (5CA) Cat18 1200/150 Mbps, 5G 7.5 Gbps DL
