Reply
Highlighted
Re: Will Google's new Pixel 4a work on Public Mobile?
Hi on2wheels. I tried the selections as you suggested and my results were as follows.
If I turned my wifi and mobile data off then apps could no longer access the internet. The MMS on off had no impact. Swithing wifi or Mobile data back on controlled the app access in accordance with my Data Saver Selection. In my case I use the Data Saver Option to prevent large downloads over my mobile data plan. IE: Radio Paradise App on Wifi Only. This does not seem to align with your results. Not sure what is different ohter than you have reversed the developer option selection. Hope this helps but as someone commented there is no notifications for you to see this.
