Wifi calling and sms textiing
dnewf
Hi people I have a samsung S6 just regular not edge.model number SM-g920w8. android version 7.0. Last update was june 1 2018. I been trying to turn on wifi calling with no avail. I dont see anything saying wifi calling. Is there any hope without upgrading the phone?
10 REPLIES 10
Werden203
Hi!
Wi-Fi calling is not supported. I am using a phone which used to be on the Fido network and did support Wi-Fi calling and text. When I switched to Public Mobile the options for Wi-Fi calling were not even visible in my setting any longer. It's like they were never there. I will miss it, especially on vacations. You can, however chose one of many apps which use Wi-Fi to text and call, like Telegram, but the recipient needs to have it also. I hope that this helps.
SteTem
I have used Whatsapp for wifi calling without any problems from Florida to Ontario
Triguy
PM does not offer wifi calling.  You could use apps like Skype, WhatsApp, Textnow, or Fongo.
geopublic
@dnewf  WiFi calling is not supported by Public Mobile so no need to change phones. I think running Android 7.0 with all the security vulnerabilities should be a concern though and you should consider upgrading to a more secure option like a Google Pixel or an Android One model that is running the latest Android version and receives security updates on a monthly basis.
@dnewf wrote:
there's no wifi calling? well didn't know that. Looks like i will have to move on after 2.5 years. I cant get sms to work with wifi. yes FB messenger i really don't want that. I work out in the bush out company provides wifi and i need wifi calling.
google messages app has rcs which uses wifi or data for text
dnewf
@dnewf wrote:
i have google hangouts working with out going calls but not sms. Yes its my phone. didnt know about text me
https://www.textnow.com/
benfatto
@dnewf  PM does not support wifi calling at all. So, new phone won't help.
On the other hand, all PM Plans, except for data only, fully support SMS & MMS.
dnewf
@dnewf wrote:
Hi people I have a samsung S6 just regular not edge.model number SM-g920w8. android version 7.0. Last update was june 1 2018. I been trying to turn on wifi calling with no avail. I dont see anything saying wifi calling. Is there any hope with upgrading the phone?
If I interpret you right...this place doesn't offer wifi calling. You can certainly use third-party apps like TextNow and many others.
So it's not your phone.
