Which LG G6 is best?
shwng
I'm thinking about buying an LG G6 on ebay but I don't know which model will work or be the best to use in Canada/with PM.  H870/DS/1/2/3, A47 or another type I should be looking out for?
10 REPLIES 10
ba14ii
ive been using the LG-H873 for 1-2 years now. very good phone no complaints at all, my dad also has the same model. being said, since its the canadian version depending on who the original carrerier was it may come with some bloatware!
@hycm53 wrote:
Check the phone you are going to buy on these two websites:
https://willmyphonework.net/
https://www.kimovil.com/en/frequency-checker/CA
The first site willmyphonework...is now the same on the page of public mobile GET STARTED.Smiley Happy
hycm53
bridonca
@shwng wrote:
Would you think H870 would be more benneficial while travelling or would that not really matter?
It would probably not matter not much.  You might not be able to get all the frequencies available, but the phone will use what is available to it.
I usually make a point to buy a phone designed for Canada, because it has been specificly tested to work on Canadian gear.  In regards to the LG G6 though, it probably will not make much noticable difference.
shwng
Most are from the US @Lieux
@shwng wrote:
Yeah, the G6 isn't on the list @Lieux
And thank you! @bridonca
Ok...is it a seller from Canada or US?
shwng
shwng
Lieux
Did you check on the new checker for compatibility here....on the GET STARTED...https://www.publicmobile.ca/en/on/get-started ?
bridonca
They will all work. The LG-H873 is the Canadian version.  The H870 is an international version, and should also work
