Reply
Re: WARNING! iOS 13
Pull sim, reset carrier settings, put sim back in, reboot.
Re: WARNING! iOS 13
@hangingkayakerFirst swap the SIM to make sure it is a problem with the phone or your Public Mobile account.
If it is really a problem with the phone. Turn on your phone's DFU mode and you can restore a backup of your iOS.. (of course you have to had made backups in the first place).
Re: WARNING! iOS 13
@Obice wrote:
As you can tell, none of this is carrier/network related... Just Apple being lazy and not releasing solid structured software (I would bash any company for doing the same, FYI).
No kidding they bit too much off and screwed up royally.
I wonder if my touch issue is due to having a tempered glass screen protector. But my touch problem was with texting only and all else was good.
Re: WARNING! iOS 13
pulled sim but now can't access Phone or Cellular settings (NO sim)
Re: WARNING! iOS 13
Can you not sign it onto wifi?
Re: WARNING! iOS 13
DFU?
Re: WARNING! iOS 13
Really. DFU allows you to get the old iOS back??. I had to download the IPSW file and do the iTunes process. Then restore the phone from an older backup.
Re: WARNING! iOS 13
@hangingkayakerHow to access it varies with models so you should google your specific model on how to do it. However do make sure you have a desktop machine with iTunes installed in order to be able to use it effectively.
Re: WARNING! iOS 13
This  is what I did.
https://ios.gadgethacks.com/how-to/downgrade-ios-13-back-ios-12-4-1-your-iphone-using-itunes-finder-...
Re: WARNING! iOS 13
