Reply
Highlighted
Voicemail unavailable
Since switching to public mobile, with a plan that includes voicemail, every time I try to call it says voicemail unavailable. using an Iphone 6, same phone I had with different carrier previously and it always worked. Is there something on the phone that needs to be turned on?  My voicemail was activiated.
Highlighted
Re: Voicemail unavailable
Did you port your number in?
Does everything else work?
You'll have to contact moderators.
Or by private message.
                       Click Me
Highlighted
@gw4156 habe you tried using another pgone to access your voicemail? Call your number and press *to interrupt voicemail and enter password. If this works, then it's a problem with your phone setup.
Highlighted
Press 1 and hold your dialer will access your voicemail.
Highlighted
Highlighted
According to this @gw4156 , your voicemail number may not be correctly programmed into your phone.https://thecellguide.com/how-to-fix-voicemail-button-not-working-on-iphone-6s-228
 Use this list to figure out which one to program in https://productioncommunity.publicmobile.ca/t5/Discussions/Updated-list-of-Voicemail-Access-Numbers/...
Highlighted
Don't understand what porting a number in is. Can you explain?
Highlighted
Porting a phone number is to transfer your phone number from your old provider to a new provider,
Highlighted
Have you set up your voice mail account?
Highlighted
@gw4156  Call 647-580-4001 . Do you reach Public's voicemail? If yes, the issue is your phone settings it's pointing to the inverter number.
