Reply
Highlighted
Voice mail
Bonjour, i just transfert from kooko to public mobile and i don't have my voice mail anymore.
Accepted Solutions
Highlighted
Re: Voice mail
Good morning @audet1961 did you set up your PM voicemail? And by transfer did you port from Koodo, what type of account was it? And when was it done? What is the  make and model of your phone ? Thanks.
All Replies
Highlighted
Re: Voice mail
Highlighted
Re: Voice mail
Once you transfer to PM I believe you would loose all your vm from koodoo.  You would have to setup your PM voicemail.
Highlighted
Re: Voice mail
Highlighted
Re: Voice mail
It says that i don't have voicemail Number on my sim card
Highlighted
Re: Voice mail
@audet1961 is that the message that you get when you hold down 1 on your phone? What's the make and model of your phone?
Highlighted
Re: Voice mail
I did set up my voice mail but  it is not on my SIM card
Highlighted
Re: Voice mail
Yes  it a LG X power 2
Highlighted
Re: Voice mail
If you press and hold 1 down @audet1961 , can you access your voicemail ?
Highlighted
Re: Voice mail
No i have to enter my cell #
