I'm trying to set up a New Phone on an Active Account-
I choose Automatic Network in Setting but it says try again Later.
Sim Management is Turned on to TELUS and Shows Phone Number
All voice Call/Video Call/ Messaging is Greyed Out
___________________________________________________
Under Mobile Networks
Data Connection
Preferred Networks
TELUS (3G)
302880(3G)
Etc..etc...
3G Service
Network Mode 4G
2G/3G (auto)
3G only
4G (which is Selected)
I've Toggled with the these but to no Avail.
It is also Dual SIM and I've Tried the Other Slot
____________________________________________________________
I've Seen another Post which someone suggests they top up their PM Account with $1
to perhaps "Refresh" - Which I haven't tried - Do you think it could be the Problem in this Senario?
The Phone is an Android V.8 -M20 which was bought from China
I'm pretty sure when I bought this phone last year the FREQ was Good for PM...
Query:
Should I have to go to my PM Account to Change or Re-Enter Information?
Thanks everyone.
What is the brand of phone ? Public Mobile uses the following frequency bands: 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS). HSPA: 850 MHz, 1900 MHz (UMTS).
If your phone is compatible then you should be able to put in the sim over.
The Phone is an M20 From China.. and I'm Pretty Sure When I Bought it was Good for those Frequencies
The M20 only has 2 out of 9 4G bandz and 2 out 3 3G bandz but theres conflicting info out there as evidenced below.
Edit: Heres what i could find on the chinese version:
Edit: Heres the APN settings and info on your phone:
https://apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-m20
I guess you are saying it does not work with PM?
(though it shows Telus Network)
I also have a Galaxy GT ..(7530)? - I'll see if I can find the SIM SLOT and try that one....
It will but not very well....great phone but that version isnt made for the north american market. Where's the other phone from?
That one is worse if its from india....
Other names: | GT-S7530 |
Dimensions: | 121,6 x 64,1 x 10,5 mm |
Weight: | 119 g |
GSM frequencies: | 850/900/1800/1900 |
Standard UMTS: | 900/2100 |
Standard battery: | Li-Ion 1500 mAh |
Stand-by (max.): | 2G: 530 h 3G: 420 h |
Talk time (max.): | 2G: 12,7 h 3G: 7,8 h |
Internal memory: | 8 GB |
RAM memory: | 384 MB |
Memory cards: | - |
Operating system: | MS Windows Phone 7.5 Tango |
Processor: | Qualcomm MSM7227A 1,00 GHz Number of cores: 1 |
GPU: | Adreno 200 enhanced |
@Darren_M : Can you post the full make/model/submodel of both phones.
gishan.net says the M20 is 50% compatible.
M20 should have enough bands to work. I had another phone with the same bands and working ok in GTA area..
