Reply
Re: Unlocked Cellphones.
Telus uses CDMA NETWORK n Rogers uses GSM. So, How come an UNLOCKED Telus phone world on Rogers n note PUNLIC MOBILE? Sometimes when u insert a son cars n u dont have network, fo to the Phone setting n Search for the network manually then pick Public Mobile or whichever carrier u r looking for on the result list.  I hope this will help!!!!
Regards,
@walbornoTelus retired CDMA a long time ago.
i was wondering if u can unlock my phone
@timhortons86Public Mobile can only unlock phones from the Telus network. Other phones you will need to contact the network where you got the phone from or if the phone is purchased after 2017 the manufacturer. It depends what kind of phone you are talking about. It is up to Public Mobile's customer to  bring phones that are compatible and unlocked to use the service.
Moderator
If your phone is with Rodgers, only them they can unlock your phone.
If it is in Rogers.......mail me with imei, Phone make and model. I will try to unlock it for you through Rogers.
