Unable to recieve or send picture messages : Jethro SC729 flip phone
geraldvallee
Hi everyone, I am able to recieve text messages, and make calls but i am unable to send or recieve pictures.
I recieve a message with a picture and to view I am prompted to download the picture but I receive a Comm error, And when i try to send a photo I get a Failed to send message.
When trying to create a network (through connectivity) my options are:
Account name
APN
Username
Password
Auth. Type (only options are Normal or secure)
Advanced settings:
Homepage
Connection type - Only can choose between HTTP or WAP
Use Proxy - Y/N
Proxy address - 000.000.000.000.000 (i have tried to simplify it to less that 3 digits but I am unable to)
Proxy port
Proxy username
Proxy password
Primary DNS 000.000.000.000
Secondary DNS 000.000.000.000
IP Address 000.000.000.000
Subnet Mask 000.000.000.000
I have already tried following instrcutions on this page without any success: https://productioncommunity.publicmobile.ca/t5/Getting-Started/MMS-Issues-LG-G4-new-Public-Mobile-pl...
Thank you for any help anyone can provide
15 REPLIES 15
@geraldvallee wrote:
I tried the method without a proxy port but the IP address did not allow for the final set of numbers (80)
And try that home page without the mb/
And try all of this under WAP as well.
I hope you're talking about using proxy address and not ip address for one of the tests.
btw great job with the pics. 🙂 very helpful for trying to help you.
cell phone 2.jpgI tried the method without a proxy port but the IP address did not allow for the final set of numbers (80)
Ok ignore the 80. Restart your phone after the changes and test to see if it works
geraldvallee
Account name Public Mobile
APN sp.mb.com
Username
Password
Advanced settings
Homepage http://aliasredirect.net/proxy/mb/mmsc or http://aliasredirect.net/proxy/mb/mms (if the first one doesn't work)
Connection type - Only can choose between HTTP or WAP HTTP
Use Proxy - Y/N Y
Proxy address - 074.049.000.018
Proxy port 80
Proxy username
Proxy password
I would vote putting the ip address into the proxy address and a Y and the port. I have seen that aliasredirect work for someone that didn't have the mb/ in there.
Otherwise...nice one geopublic. More options for the OP to try.
@geraldvallee  Option #2 as per @Anonymous  recommendation if Option #1 does not work.
Hope it works!!
APN sp.mb.com
Username
Password
Advanced settings
Use Proxy - Y/N N
Proxy port
Proxy username
Proxy password
IP Address 074.049.000.018:80
geopublic
APN sp.mb.com
Username
Password
Advanced settings
Use Proxy - Y/N N
Proxy port
Proxy username
Proxy password
Both HTTP and WAP have the same input options for proxy settings
Hmm. How about a pic of the screen before these?
geraldvallee
If i try to simplyfy the Proxy numbe ri can only change it to 200, it wont allow me to leave it blank, or reduce it to less than 3 numbers per section
Is that under HTTP or WAP? Or do they both end up with those options?
How about...does your phone even support doing MMS? Having an APN setting area could just be for the little internet browser.
geraldvallee
Phone issue.jpgIf i try to simplify the Proxy number i can only change it to 200, it wont allow me to leave it blank, or reduce it to less than 3 numbers per section
I have tried these settings but the proxy can only be entered in 000.000.000.000
I am able to enter the proxy as 074.049.000.018 but still no success
Would you be willing to transcribe (or better, screenshot) the settings available after choosing HTTP and then also after choosing WAP?
Someone recently went through doing settings for a flip phone and they look a little familiar.
geraldvallee
@geraldvallee Do you have the user manual? https://www.jethroshop.com/sc729support
You need to set up the APN to match PM's: https://apn-canada.gishan.net/en/apn/public-mobile
Input this info:
➡ Name: Public Mobile
➡ APN: sp.mb.com
➡ MMSC proxy: 74.49.0.18
➡ MMSC: http://aliasredirect.net/proxy/mb/mmsc
➡ MMS port: 80
➡ MCC: 302
➡ MNC: 220
dabr
Account name
APN
Username
Password
Advanced settings:
Homepage
Use Proxy - Y/N
Proxy port
Proxy username
Proxy password
Is your data enabled? Data has to be on to both send and receive MMS..also try to turn airplane mode on/off too...that one worked for me.
