Reply
Highlighted
Re: Umidigi A3S problem
@trooper0169 try these settings
Highlighted
@trooper0169  can you post a screenshot of the settings you have so we can take a look? Thanks!
Highlighted
I tried the settings in the original post on the A3S problem
Highlighted
What about the other entries above the MMS Proxy entry?
Highlighted
@trooper0169
Try these settings. Let us know if they work for you.
Highlighted
@trooper0169
Try these settings below.
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: Not set      - or - default,mms,supl   ( if your mobile hotspot is spotty add "dun")
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
Manually change and save them. Enable data and try to send an mms text message or surf the net. If you still require help. Please ask. Stay safe.
