UNLOCKED BlackBerry Z10 STL100-3
ahsan_khan_46
May be this question asked before
But for my satisfication I want to ask this question again
Please confirm me  that
is compatible with  Public Mobile or not
I just lost my cellphone and now want to renew
my plan with this phone
Please help
Thanks
39 REPLIES 39
ahsan_khan_46
Thanks Martin
In order to safe time
Do I need to buy the tel first then order SIM card
or can I do both at the same time
Please tell me again HOW to reactivate the existing no
Presently my no. is temporarily suspended
I appreciate for  your help and quick response
Martin
Legend
Legend
Hello,
The tri-punch SIM card is free. Go to the homepage, and click the order link. You will be required to create a MyShopify account before ordering. In approximately 3 to 7 business days, your card will be delivered by your Canada Post letter carrier.
In order to reactivate your number, purchase a plan if your account has been in expired status for 90 days or less. If it's been longer than 90 days, your account was deleted and deactivated, and your number lost forever. If this is the case, you are no longer considered a PM customer, and must start the entire process of becoming a customer once again.
FYI.
ahsan_khan_46
Thanks guys for your help
One more question
After buying my cell phone
I have to order SIM Card from PM
how much does it cost
What is  the procedure to reactivate my no
Thanks
jgalpin580
yes that phone will work on the public mobile network, when I first signed up I was using a blackberry z30 unlocked phone, and it worked fabulously on the network!! Hope that helps and enjoy your public mobile service!! 🙂
IWIK
Skype has been moved from BlackBerry App World to Amazon App store. Which comes preloaded with OS 10.3 and up
imm1304
Skype has a history of being extra buggy/laggy on BB.  My brother always had an issue with skype on his Z10 couple of years ago.
I just did a quick search on the BB appworld for skype and its not even there. You will have to download it from skype.com.
Whatsapp should be fine, they are known to make a good app for all platforms.  Its a good phone overall, however, you must find it for a very low price othewise go for an android alternative.
ahsan_khan_46
Thanks Guys
One more question
How about using Whatsapp  and Skype
on Z 10
any problem???
I am not a heavy user
Normal use for calls
but want to use  Whatsapp and Skype
Please give me  your feed back
Thanks again
Here's a full list of the phone's specifications that show that both variants of this phone would support PM' 850/1900 MHz 3G network, and also its 1700 MHz FDD-LTE network:
http://www.gsmarena.com/blackberry_z10-5251.php
7789849803
@ahsan_khan_46 Yep - that phone will work on PM without a problem, and you'll have access to both the 3G as well as 4G networks.
