04-06-2020 08:44 AM - edited 01-05-2022 10:15 AM
Since I am with public mobile from Feb until now I was unable to receive calls.....I think I will change provider......
04-10-2020 05:31 PM
try resetting your network settings
goto settings
general
scroll down to reset
then press reset network settings
enter your passcode if you have one
then restart
you will have to re-enter all your wifi passwords
04-10-2020 02:34 PM - edited 04-10-2020 02:46 PM
Check your self serve account. If you have limited minutes and none are showing then you have used up your alotment. You can purchase an add-on for $5 for 500 Canada-wide Long Distance calling. Try rebooting your phone. Also try the lost/stolen feature. Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone.If you still need assistance then submit a ticket by clicking on the question mark on the bottom right.
04-10-2020 02:31 PM
I have a similar issue, although mine is infrequent. Have a Samsung S5. Anyone else?
04-10-2020 01:53 PM
I had this same issue with my phone. It sounds like you may have ported your phone number and the port may have failed. I abandoned my old number, switched to a new one and the issue went away immediately. You just need to be willing to drop your old number. Good luck!
04-06-2020 09:16 AM
@Dorisslw Here's an Apple support article on Ipone 6 not receiving calls. https://support.apple.com/en-us/HT204027
Try these fixes. Also, to make sure, you can make call and send/ receive all texts including mms messages, right? Thanks.
04-06-2020 09:15 AM - edited 04-06-2020 09:17 AM
@Dorisslw , check your self serve to confirm the number associated with the account. Did you do a number port? Alternatively there could be a provisioning problem with the account. You would need moderator team assistance to reset the account. The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
04-06-2020 09:10 AM
it is an iphone 6 calls never get through....when calling the # a msge saying "I'm sorry the# you're calling not available at this time"
04-06-2020 08:55 AM
What is the make and model of your phone? @Dorisslw can you switch the SIM into another phone so we can determine if its a phone or PM problem? Are all calls not coming in? Or are the calls going directly to voicemail? Thanks.
04-06-2020 08:54 AM
hello unfortunately it didn't work..... still cannot receive calls
04-06-2020 08:50 AM
When you log into your self serve account - what is the status ? Try rebooting your phone.
