09-10-2020 11:25 AM - edited 01-05-2022 01:09 PM
Hi everyone,
I've been using PM services since December and everything worked fine. But for the last month I'm have issues sending and receiving SMS. Nothing can be received nor send unless I'm connected to WiFi or I turn data on (It's turn off from the beginning barely have any data). Once connected, got notification for all the messages received and send all the messages I composed while I was offline.
I'm using a Motorola Moto E6 with Google Messages (came as default app)
My plan includes:
- 100 Minutes Canada-Wide Talk + Unlimited Incoming Minutes
- 250 MB Data
- Unlimited International Text
09-10-2020 04:14 PM
@geopublic wrote:@chrisco When you disable chat features that means that Google Messages will not use RCS for texts (texts over Wi-Fi or data).
Note it can take many hours for your number to de-register from all network provider's RCS servers so that might be the reason you are not receiving the texts immediately.
Turn chat features off and wait until tomorrow and test again.
I turned it off again and I'll wait. I know I have a pending message, so let see when it will get in.
09-10-2020 03:22 PM
@chrisco wrote:
@geopublic Go into Messages --> Settings and disable chat features.
I tried that, I was able to send messages, but was unsuccessful on receiving them
09-10-2020 02:49 PM - edited 09-10-2020 04:38 PM
go to Google Play store and update all your apps especially "carrier services" and Google connectivity services
contact customer support mods to reset your network from their end. did you renew your plan recently?
make sure to check your inbox(top right corner envelope icon) periodically, for a response
09-10-2020 02:42 PM
@Anonymous wrote:Go into Apps and clear cache and maybe even data and then force close. Restart. See what happens.
Did that without luck. Cache & Storage
09-10-2020 02:20 PM - edited 09-10-2020 02:20 PM
@chrisco wrote:I tried that and reset everything. No WiFi, no Bluetooth and data turned off. I sent a test SMS that I didn't received.
Than I tried on and off the chat feature without luck. Same with Group Messaging.
I turned the data on and got the message instantly.
09-10-2020 02:13 PM
@gpixel wrote:
- remove your sim turn off the device, turn on the device and reinstall the sim.(while the sim is out make sure the metal contacts are clean)
reset your network settings
- open settings
scroll down to system
tap on reset options
tap reset wifi,mobile & Bluetooth
tap reset settings and restarti don't know if it's just the Google messages app, but I'm able to send MMS over wifi.(RCS chat features disabled)
09-10-2020 01:29 PM
09-10-2020 01:13 PM - edited 09-10-2020 01:33 PM
@gpixel : interesting. My S7 doesn't grab the buffer even though it flicks data on and off.
09-10-2020 01:05 PM - edited 09-10-2020 01:28 PM
I am using Google Messages app on my A5 Pro.
MMS uses mobile data which needs to be enabled. MMS cannot send/receive on WiFi.
I have an old $10 50/50 plan without plan data. I enabled data in order to send/receive MMS. Google Messages app tells me what (SMS or MMS) was used to send/receive.
What is yours values for the following parameters on your APN settings:
MMSC http://aliasredirect.net/proxy/mb/mmsc
MMS proxy 74.49.0.18
MMS port 80
09-10-2020 01:04 PM - edited 09-10-2020 02:15 PM
@Anonymous wrote:Does her phone have group messaging on? If so does she have auto-download MMS on?
Don't change hers. Just check it.
It's on mms for her too. I switch mine to sms and I'll wait to see what happens
09-10-2020 01:01 PM - edited 09-10-2020 02:16 PM
09-10-2020 12:40 PM - edited 09-10-2020 01:34 PM
@Anonymous lol I know it's a little redundant. it's part of my copy paste though 😅
I'm gonna test that out right now to see if the buffer gets enables when only wifi is on. that should tell us wether it's using wifi or data. I'll post my findings on here in a bit
*youre right "z" my buffer in self serve was enabled when sending through wifi. I'll try this again with no internet connection.
*no internet connection, it took a bit longer.. it said "waiting for internet connection" then it said done. so the software is automatically toggling the data. 👍 I went on the pc to check the buffer. the buffer was again, enabled
09-10-2020 12:40 PM
@chrisco wrote:Hi everyone,
My plan includes:
- 250 MB Data
@chrisco Go into Messages --> Settings and disable chat features.
09-10-2020 12:25 PM - edited 09-10-2020 12:26 PM
@gpixel wrote:
- tap reset settings and restart
...after re-inserting the SIM 🙂
Edit: after your edit...are you sure it's not flipping on/off cell data? That's interesting.
09-10-2020 12:23 PM - edited 09-10-2020 12:24 PM
09-10-2020 11:50 AM - edited 09-10-2020 11:51 AM
@chrisco wrote:I had data turned off all along and it work before. My girlfriend has the same phone/plan and hers work with data turned off. I tried to match her settings, but mine still not working
09-10-2020 11:44 AM
09-10-2020 11:38 AM
@Triguy wrote:You need data enabled to send texts even though it does not count towards your data usage.
Check your settings to see if you have wifi enabled to send messages.
...as MMS yes.
MMS doesn't go over wifi though either. (except that tree fruit brand)
09-10-2020 11:30 AM - edited 09-10-2020 11:32 AM
09-10-2020 11:29 AM
My plan includes:
- 250 MB Data
Sounds like you're doing all MMS. Is there a setting to default to SMS?
