Reply
Highlighted
Text Message to 7723
I have a Samsung S8 and my phone appears to send random text messages to 7723. I  see other have the same issue but do see any resolve. I see references to visual voicemail but I don't have a option to enable or disable it. (at least that I can find)
Any suggestions?
Tags (1)
Highlighted
Re: Text Message to 7723
Maybe take a look at thread below?..there's suggestions in it to disable permissions.
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Monthly-texts-being-used-up-but-I-m-n...
Highlighted
Any suggestions?
Try turning off visual voicemail as per @NDesai 's instructions provided here:  https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Pixel-on-Oreo-tries-to-send-Int-l-SMS...
Highlighted
Any suggestions?
@LarryI  Check the settings of your dialer app. There should be an option to disable vvm.
