Reply
Highlighted
Re: Some Messenger responses not coming through
he there,
So I tried this and it didn't work either. I am super confused what this could be caused by.
Thanks for your reply.
Highlighted
@Ihanrath What messaging app are you using, or is it just the one that came with the phone?
>>> ALERT: I am not a moderator. Je ne suis pas un moderateur.
Highlighted
Hello,
Just the one that came with the phone. Thanks
Highlighted
@Ihanrath
Hi, just check the message settings to see if you have blocked those contacts by accident
Highlighted
I am using microsoft. You are the first person that thought of it being the app so I looked up reviews of this app and noticed similar problems. Do you have a suggestion for a better one?
I see that Messenger SMS & MMS is higher rated. Do you know anything about that one?
Thanks
Highlighted
Good thought but not blocked. Thanks
Highlighted
@Ihanrath search for Google messages app under Google LLC
what is the make and model of the device?
It is a Q6 Android LG phone. Has never given me any problems til a month ago.
what are the providers of the 3 contacts you can't message?
did you reset your network settings?
  • open settings
  • scroll down to "restart & reset"
  • tap "network settings reset"
  • tap "reset settings" and tap again to confirm
  • then restart the device
Highlighted
Highlighted
You also asked about the providers of the three contacts in question. Funny two of them are with Public Mobile and third with Bell but they all have an older model iPhone.
Highlighted
@Ihanrath hmmm.. maybe an update on their iPhones changed a setting and is preventing them from messaging you. its most likely an issue on their end.
are you the only android user in the group? can they text to other Android users?
contact customer support mods to reset your sim network on their end
make sure to check your inbox(top right corner envelope icon) periodically, for a response
