My service is unavailable and I'm wondering why.i paid for the service and all of a sudden I can't call text or use my data. Can you look into this for me please and thank you
@Madmonigan wrote:My service is unavailable and I'm wondering why.i paid for the service and all of a sudden I can't call text or use my data. Can you look into this for me please and thank you
Can you login to your self-serve account? If so, does the status say Active? If so, can you use the Change SIM function and take note of the last 4 digits of the registered SIM card #. Then compare that to your actual SIM in your phone. Are they the same?
Log into your account and click change sim card.
It will show the last 4 digits of the sim card. Take the sim out of your phone. Do they match?
Dial 611 to hear the status of your account. If you have a valid credit card on your account, you can also pay for next renewal if it's run out.
Keep us updated.
Hello I'm still having trouble with sim card. I checked the numbers and they match. I can't even dial 611 to check either. So I dont know what other options I have to do
@Madmonigan wrote:Hello I'm still having trouble with sim card. I checked the numbers and they match. I can't even dial 611 to check either. So I dont know what other options I have to do
Go back into your self serve account and immedaitely change your password and security quetsion. Report your phone as lost/stolen and then open a ticket at: https://publicmobile.ca/chatbot to have service restored on the proper SIM card.
Did you reboot phone? Reset network settings? What have you done? Model of phone?
@Madmonigan , What is showing on your phone ? SIM not-provisioned? No service?
Also, if you have checked the SIM last 4 digits on your SIM card match with My Account , then it's good--at least not SIMjacked. Try to turn off the phone, re-sit the SIM firmly, restart the phone and see.
@computergeek541 The OP said the numbers matched?
Sorry. I misread.
