Sim activated but can't message, phone or data
SilvaDave
Hi,
 My daughters phone was working, but  barely. It did receive and send a call or two. As well as texts. It now shows thats it's on the public amobile system and has several bars but can't send or receive calls or texts. And no data ether. If I phone i get -It says call *611. I call 611 and it says come here. I tried my public mobile card in her phone and it works fine. I also tried my wifes fido and it worked too. It is an Iphone 6S.
Is this an activation error?
Do we need a new sim card?
Please help
9 REPLIES 9
SilvaDave
all working. public mobile needed to reactivate.
@SilvaDave wrote:
Done this several times. Also completely reloaded the phones software 3 times now.
The phone works with other sims not the current one. Was even able to change it's number through account. Tried the lost or stolen hack etc.
pretty much have tried every hack that has been posted on this site.
Did you try the additional $1 "hack"?
Maybe clean the SIM contacts.
Could just have become a bad SIM.
Can you post a screen shot of your APN settings?
SilvaDave
will13am
@SilvaDave, I suggest starting with logging into the new account and see if it is active.  The self serve should be able to provide a current status for your service.  Assuming that everything in the self serve checks out, you should be able to connect to the network with the SIM that was used in the activation.  If there is problems connecting to the network, you can try doing a network reset on the phone.
SilvaDave
This automatic on iphone
SilvaDave
New number and daughters SIM does not work in my or my wifes phone
Check APN settings on the phone..
They should be as followed.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Then restart phone
Dunkman
@SilvaDave
Did you port your number or activate a new line?
Can you put your daughter's SIM card in your phone or wife's phone?  To help determine whether hardware issue versus PM service issue.
