04-01-2020 11:27 AM - edited 01-05-2022 10:11 AM
I'm in an area with a weak signal. It varies from 1 bar 4G to 2-3 bars 3G. I can make calls and text but when it drops from 4G to 3G I lose data connectivity for some reason. I know that the PM data is at 3G speeds, but I think 4G connection is required?
My question is, will a signal booster help me? And if anyone has experience with signal boosters please let me know what works for you.
04-02-2020 12:41 AM
Okay that makes sense.
04-01-2020 07:52 PM - edited 04-01-2020 08:01 PM
@Gerry_P 3G performance at cell edge is terrible, often unusable as you are experiencing, which is why I advise people to not force their phones to 3G only. The site you are using is capable of delivering data on 3G and 4G... You would just need to be in a better coverage area for 3G to be stable.
Unfortunately I can't recommend boosters as I don't have any experience with them. If not installed responsibly, boosters can cause network interference.
04-01-2020 03:32 PM
@Gerry_PSee if telus hub is available there....it might be a good option for you.
04-01-2020 02:19 PM
No, I don't have WiFi there, it's my summer cottage. And I have an online job now so I need data when I'm there although I may have to end up getting WiFi installed by the look of it.
04-01-2020 01:59 PM
04-01-2020 01:58 PM
@Gerry_P do you have WiFi? If you do, a possible work around would be using a voip app such as TextNow and use it over Wifi to make / receive / send calls and texts in Canada and to the United States for free.
04-01-2020 01:48 PM
@gblackma , check your information before posting inaccurate nonsense. OP is asking about data and so how does WiFi calling which Public Mobile does not support help the situation?
04-01-2020 01:45 PM
@Gerry_P , not being able to get data flow on 3G is a sign that there is lots of call traffic. I get the same issue at work where the company phones clog up the 3G spectrum. During off hours, data flow on 3G will work. This behavior is not dependent on signal strength, just network load.
I have the Umidigi F2 which is pretty good with picking up a signal. As for signal boosters, don't waste your money, especially for garbage that is under $100. Why would a cheapo device like that perform better than the phone itself?
04-01-2020 01:43 PM
@gblackma Data is available on any connection. There's no such thing as data only on 4G
Actually you are incorrect, as soon as the signal drops to 3G the data quits working. Once it picks up 4G again the data works.
04-01-2020 01:36 PM
Yes to all questions but I still need to boost the signal inside the house. That's what my question was. I was looking for advice on boosters.
04-01-2020 01:33 PM
04-01-2020 01:32 PM
@Gerry_P I found this link to the 10 best cell signal boosters https://wiki.ezvid.com/best-cell-phone-signal-boosters
04-01-2020 01:25 PM
I can but I don't get any data over the 3G network. I want to boost the signal so I can get a constant 4G.
04-01-2020 01:25 PM
Thanks @sheytoon . I was trying to say that the cell tower in the area may have only have 4g data signal capability.
04-01-2020 01:12 PM
@gblackma Data is available on any connection. There's no such thing as data only on 4G.
04-01-2020 12:22 PM
@Gerry_P mine is the F1 too. Do you have enhanced LTE mode on? And WiFi calling on? Also if you hit preferred networks - public mobile(3g/4g) - network type - see if both 3g and 4g are selected. If not, select both of them. Thanks.
04-01-2020 12:19 PM - edited 04-01-2020 01:15 PM
@Gerry_P wrote:I'm in an area with a weak signal. It varies from 1 bar 4G to 2-3 bars 3G. I can make calls and text but when it drops from 4G to 3G I lose data connectivity for some reason. I know that the PM data is at 3G speeds, but I think 4G connection is required?
@Gerry_P The 3G network is only required for calls. Texts and data will work both on the 3G and LTE (4G) network.
What type of a phone are using? If you are using an older phone might want to look into a new one for better coverage.
04-01-2020 12:00 PM - edited 04-01-2020 12:00 PM
@Gerry_P Can you force your phone to connect to 3G by default? It may solve your issue. When you will do it, turn off your phone, wait for 30sec and turn it on.
04-01-2020 11:54 AM
I found 850 mgz signal boosters on eBay for around $55 USD
04-01-2020 11:52 AM
My phone is a Umidigi F1
Thanks,
Gerry
04-01-2020 11:37 AM
Signal boosters are going to cost a lot of money.
What cellphone do you have? Maybe it's best to upgrade the cellphone instead?
Let us know.
04-01-2020 11:34 AM - edited 04-01-2020 11:38 AM
@Gerry_P there may be only 4g LTE data connections in your area. Is there an option on your phone to enable it to switch automatically Between the 2 options? Or one to choose either 4g or 3g? You can also try your SIM in another phone to see if the signal quality improves.
