Samsung galaxy a20 compatibility?
jdboulanger
My husband wants to switch to PM (I've been using PM since last year)
His phone is a Samsung Galaxy A20
Model SM-A205W
I am not very knowledgeable about cell phones, and the phone is not listed in the compatibility checker!
Thanks for your help!
7 REPLIES 7
@computergeek541 wrote:
Model SM-A205W
@jdboulanger  Any A20 Samsung purchased in North America will work on Public Mobile.
I haven't checked the specifications of every version availiable world-wide, but purchasing in North America doesn't ensure an appropriate variant. A seller could import a phone from anywhere.
As for this particular model of SM-A205W, this is a specific Canadian variant. In this day, Samsung wouldn't realease a Canadian-specific variant without it being compatible with Rogers, Bell, and Telus (and even Freedom, Videotron, Eastlink these days).
@computergeek541  Purchasing in North America meaning from an authorized reseller location. (Not Kijiji or otherwise.)
Model SM-A205W
gblackma
@jdboulanger your husbands phone is 100% compatible. It has the required 3g and 4g LTE bands.
https://www.phonemore.com/specs/samsung/galaxy-a20/sm-a205w/ . Make sure its unlocked and keep the account active if porting his number, the port will close it.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Stay safe.
Triguy
It should be compatible according to these specs.  https://m.gsmarena.com/samsung_galaxy_a20-9640.php
Make sure it is unlocked.
Staliger
@jdboulanger Yes, the phone will work with PM. Don't worry. Make sure it is unlocked though.
geopublic
Model SM-A205W
tabi159w
The compatibility checker is out of date, but don't worry, your husband's phone is completely compatible with Public Mobile. Remember to refer your husband so he gets a $10 credit!
