11-12-2019 08:34 PM - edited 01-05-2022 07:57 AM
Hi,
I am setting up a phone for my brother-in-law. It is an older Samsung S3.
The data won't work.
When I go into APN settings, I see two already there, even though I did a factory reset and a cache clear on the phone. One is TELUS SP and the other is TELUS ISP. I don't see an option to delete these, only to add new ones.
I added one for Public Mobile, but was unable to set it up exactly as specified. The APN Type doesn't have all the options mentioned in the instructions. Plus one of the sets of instructions say the APN Type should be left blank, but it is set to Internet+MMS+DUN and I can't set it to blank as you can only select combinations of the three, or one of them.
Any ideas? Factory Reset, cache clear, set up APN as instructed. Nothing seems to work.
