Samsung Galaxy S20fe
Kathy7
is the above phone compatible with Public Mobile plans?
8 REPLIES 8
pkaraa
@Kathy7 yes it will work.
Network setting might need a review.
@Kathy7   great phone.  No problem to be used on PM
@Kathy7 wrote:
thank you. that's very helpful
@Kathy7
your welcome...
Kathy7
@Kathy7 wrote:
thank you. are you using this phone with public?
@Kathy7
my friend has one is working will with public mobile,
Kathy7
Triguy
Yes based on these specs it is compatible with PM.
https://m.gsmarena.com/samsung_galaxy_s20_fe-10428.php
@Kathy7
yes is will working with public mobile,
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
