Samsung Galaxy A10e 32GB - Black - Unlocked
phonequestion7
Does the Samsung Galaxy A10e work on the public mobile network?
7 REPLIES 7
(duplicate messages removed)
My spidey senses tell me that geminiman and lionheart are one and the same.
You're gonna get yourself banned if you keep this up.
lionheart871221
Hello
Samsung galaxy a10e works very well I have purchased one and currently using it. Thanks public Mobile. Best experience with Public Mobile so far.
 @GEMINIMAN2005
Welcome to Public Mobile. It's great of you to jump in and start participating.
Just so you know...this is a bit of an older thread as shown with the date stamp in the image below.
Also that little check mark indicates that the thread has been "solved". That means that the original poster (OP) of the thread chose a post as the answer to their question.
So posting after that is not really necessary.
Just fyi
GEMINIMAN2005
Hi,
It works I have just tried it in samsung a10e public mobile sim works very well no issues. Go ahead no worries.
mfizz55
This phone should work with PM . It supports the right bands.
https://apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-a10
Dunkman
@phonequestion7
This Samsung will work with PM.
Here are the specs;
https://www.gsmarena.com/samsung_galaxy_a10e-9790.php
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
