11-20-2019 02:08 PM - edited 01-05-2022 08:03 AM
Hello.
I cannot use a Samsung phone even though it is unlocked. It says I need to provide the PIN number. The problem is that I don't remember the PIN number. Is there any way to find out about PIN number?
11-20-2019 04:35 PM
@ksrf2004 wrote:Hello.
I'm looking for PUK code
As stated you can contact Samsung customer service online and they have provided a Master PUK code in the past or you can submit a trouble ticket here and get one from PM.
Click this link https://publicmobile.ca.ada.support/chat/ and enter your question into SIMon. Follow the prompts to get to the Contact Us button and then a Submit Ticket button will appear.
Community Moderators are available from Monday-Friday 8 am(Eastern) to 12 am(Eastern) and Saturday, and Sunday from 8 am(Eastern) to 10 pm(Eastern)
11-20-2019 04:27 PM
Hello.
11-20-2019 02:34 PM
If you purchased an unlocked Samsung and have used it with only one provider some Samsung phones are known to network lock to the provider of the first sim installed in them. So for some clarification are you looking for a PUK code or a network unlock code?
11-20-2019 02:12 PM - edited 11-20-2019 02:14 PM
@ksrf2004 If you are referring to the screen lock PIN number that was setup on your phone as part of your security settings, then no there isn't.
11-20-2019 02:12 PM - edited 11-20-2019 02:12 PM
What is the message displayed? Is it saying Enter SIM Network Unlock PIN?
11-20-2019 02:11 PM
Samsung is giving unlock codes for free :
