Reply
Highlighted
Removing carrier name from notification bar on Android
Hi. I would like to remove "Public Mobile" from the notification bar as it's blocking the notification icons from showing (I increased my font and icon size so I don't have to reach for my reading glasses all the time).
I've deselected the option in the Network settings page to "show mobile network" and have restarted my phone but it's still showing. I am using a Moto X4 on Android 9.
Thanks!
Accepted Solutions
Highlighted
Re: Removing carrier name from notification bar on Android
@beth1791
Sorry nothing concrete came up in Google searches.
Some users experiencing same issue as you with different Moto models after unchecking the box for "show mobile network"
Seen one post from someone, I guess from Motorola, saying they escalated issue.
In any event you're not the only one experiencing this. Maybe contact Motorola?
All Replies
Highlighted
How to remove your carrier's name from the Moto X status bar
  1. Open up the Settings app on your Moto X and under “Wireless & Networks,” tap “More…”
  2. Tap “Mobile networks.”
  3. Uncheck the box next to “Show mobile network.”
Highlighted
I had already tried that, and then restarted my phone, but it unfortunately didn't work.
Highlighted
Strange. I'll google some more
Highlighted
The OP already tried that and said the mobile network name didn't disappear.
EDIT: Apologies, posted this before I saw the replies above mine.
Highlighted
@beth1791
Highlighted
@Jb456 wrote:
@beth1791
Thank you so much for looking into this, I appreciate it Smiley Happy
Highlighted
Could be a bug
Highlighted
https://play.google.com/store/apps/details?id=com.teammt.gmanrainy.emuitweaker
https://play.google.com/store/apps/details?id=com.kasitskyi.hiddensettings
One of them might work (and yes, they should both run on Moto if compatible Android version).
You can also try tapping Settings/About/Version or Settings/About/Build about 7-10 times to unlock Dev Settings.
If settings (obvious, hidden, and dev) can't persistently do what they're supposed to do then the phone vendor/carrier has locked the option away from the user and you can't unlock it without rooting.
