10-20-2018 02:17 PM - edited 01-05-2022 02:13 AM
10-20-2018 03:17 PM
Yes, sorry, I called my husband using the PC Mobile SIM 😉 Thanks for all the advice. I will wait for the moderator to respond 🙂
10-20-2018 03:14 PM
HI!
Thanks for your response! It is a post paid plan with PC Mobile. It is using the same e-mail address, I believe. It never occured to me to use a different one . .
I sent an email to the moderator e-mail Thanks for your help!
10-20-2018 03:11 PM - edited 10-20-2018 03:14 PM
@amac wrote:Yes! Just called my husband 🙂
I assume you did that with the PC sim? If so do as I suggested above. Beware it make take up to 48 Hrs but be sure to include as much information as you can and explain what happened and what you have tried to fix it, including that your PC mobile sim is still working.
EDIT: As your PM sim is working fine with the new number you can use it as well., which ever you prefer. If you do this then when the port is done the old number will just show up on your phone without warning.
10-20-2018 03:09 PM
10-20-2018 03:05 PM - edited 10-20-2018 03:05 PM
@amac wrote:Thanks for the suggestion! I tried a different computer and cleared the cache. No luck :(. It is PC Mobile post paid.
If your PC sim is still working and you are unable to use the self serve to port then keep using your PC sim and send a message to the MODs. When the PC sim stops working you know the port is done.
To get help with your account, activation, or service? Please contact the Community Moderator Team to get help with your account.They are Public Mobile support employees who can help with your issue; "https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder..."
Click here to send them a private message. 'https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 '
n your message please include: PM Phone Number, 4 digit PIN, Account email address, Detailed explanation of your issue.
Don't know your pin? Provide any 3 of the following: Complete mailing address, Email address, Alternate phone number, Date of birth, Last top up date amount.
How long until they reply? Office Hours: Mon-Fri 9am to 9pm, and Sat-Sun 9am to 7:30pm [Toronto Time]. Messages are replied to during business hours and in the order they are received. Typical response time is between 1-3 hours, but can be up to 48 hours.
There is no need to send multiple messages.Some good posts/reads: Search PM GUIDE to find some great posts and answers to many common questions.
If either response to your particular request leads to the resolution of your issue , please help other community members by marking that post as the solution. Thank You
10-20-2018 03:02 PM
If you put your PC sim into your phone does it still work?
10-20-2018 03:00 PM
10-20-2018 02:58 PM
@amac wrote:It should be! I didn't contact them at all to cancel 😉
and you haven't passed your renew date with PC?
10-20-2018 02:58 PM
10-20-2018 02:47 PM
@amac wrote:Hi!
Yes I am all set up with a new number and SIM and all is working! But when I try to port under self serve, it states that I can't. I was told that I need to post here to get additional help?? Thanks!
Is your PC mobile account still active and in good standing? This is required in order to port.
10-20-2018 02:44 PM
@amac, how far into the port request did you get, when you received the 'error' message? Was your PC Mobile plan pre-paid or post paid? If it was a post-paid plan, you MUST use/have a different email address for Public Mobile. If the original PC Mobile email is the same as the email on your new Public mobile account, you will need to get moderator assistance in order to complete the number transfer.
Click here to send the moderator team a private message. Their hours are: Mon-Fri 9AM-9PM(EST) & Sat/Sun 9AM-7:30PM(EST)
You can find information regarding the moderator team by following this link.
10-20-2018 02:41 PM - edited 10-20-2018 02:41 PM
@amac wrote:Hi!
Try clearing you browser cache, an incognito window or a different browser/computer. The only issue porting tends to be with Koodo prepaid.
EDIT: Let us know if you have done that and if it works.
10-20-2018 02:39 PM
Hi!
10-20-2018 02:20 PM - edited 10-20-2018 02:23 PM
@amac wrote:Hi!
Looking to port my number from PC mobile. Can anyone help me?
Andrea
Hi,
If you have already setup and activated your PM sim then you can just go to self serve and do a port from there.
I highly recommend setting up your account with a new number, make sure everything is working, text, calls, in/out and data, then go to self serve and port.
