04-07-2020 03:37 PM - edited 01-05-2022 10:16 AM
I have an unlocked sonim xp3800 and I can't receive picture messages. Everything else works great. I have checked the APN settings as well as making sure data was turned on and nothing works. Have done factory reset and network reset as well.
04-07-2020 03:46 PM
@Dwhy wrote:The sim works in my Samsung 7
So you are able to send and receive MMS on the Samsung?
04-07-2020 03:45 PM
Sonim xp3800
04-07-2020 03:45 PM
04-07-2020 03:45 PM
04-07-2020 03:43 PM - edited 04-07-2020 03:47 PM
@Dwhy Could you please post a screenshot screenshot of your APN settings.
04-07-2020 03:43 PM
@Dwhy wrote:I have an unlocked sonim xp3800 and I can't receive picture messages. Everything else works great. I have checked the APN settings as well as making sure data was turned on and nothing works. Have done factory reset and network reset as well.
Are you able to try your SIM in another phone to see if the problem is with your phone or not since you said you already have the correct APN settings and data enabled?
04-07-2020 03:42 PM
That's exactly what I have as well
04-07-2020 03:41 PM
Yup it is on! Still nothing
04-07-2020 03:41 PM
Check your apn settings.
04-07-2020 03:40 PM - edited 04-07-2020 03:40 PM
@Dwhy hi you must have your data on to receive or send mms
