Photo messaging
FoulTrouble
I just switched to Public Mobile a couple of hours ago and I can't seem to figure out picture messaging. I have the $25 plan and I use an S7. What am I supposed to do? The ones I've tried to send just are stuck on "Sending..."
11 REPLIES 11
@Anonymous wrote:
@will13am wrote:
@FoulTrouble wrote:
Final question.
Do videos work too? or is that different?
Thanks for all the help everyone 🙂
You can watch all the video you want on wifi.  Your plan includes MMS which operates on special mobile data that is unmetered.  Data that is used to surf the net is metered and is not included in your plan.
Is video via MMS a thing?
Does animated gif count as video?  Otherwise no.
@will13am wrote:
@FoulTrouble wrote:
Final question.
@FoulTrouble wrote:
Final question.
FoulTrouble
Final question.
@FoulTrouble wrote:
So where it says "APN type" I change that from Internet + MMS to just MMS right?
Use these settings
Re-read shawnc13's first sentence.
FoulTrouble
@FoulTrouble wrote:
The $25 plan does not come with data but says photo messaging so I don't have data on in fear of being charged
This is a pre-paid service. If you don't pay, you don't get. No surprises.
FoulTrouble
ShawnC13
Make sure data is turned on even if you don't have any in your plan as it is required.  Also check your APN settings
Here is a great site to setup your APN and instructions on how to do it.  Find the APN Settings for Public Mobile here!
Do you have your data mode on? Do you otherwise have non-wifi internet access?
