05-18-2020 10:41 PM - edited 01-05-2022 10:50 AM
When I turn my phone on the warning symbol comes up and then the phone goes off again
05-18-2020 11:20 PM
Thank you very much. I will try that
05-18-2020 11:17 PM
I think you are right. It looks like it had started to charge and then just quit. A bit of red in the circle shows up
05-18-2020 11:13 PM
Your phone may display an exclamation mark in a triangle on a black screen. This screen is called recovery mode, and is usually accessed from the bootloader menu on an Android device. The most common cause of issues with recovery mode is when the device has been rooted;
Follow these steps to leave recovery mode and boot your phone normally:
A factory data reset can also resolve some software issues
05-18-2020 11:05 PM
My Nokia couldn't charge I misplaced it and couldn't find it to maintain the battery. After hours on (what it looked like) charge it couldn't go through that bootup logo, if I charge for hours it would at least go there, if I charge for 20 minutes it would show me red battery and shut off.
All my surviving adapters were 1amp (actually less), so I digged 2amp one that came with my tablet (people in my household crash them misplace them lose them or twist them all the time, I know I need to hide one in the basement that nobody will step on) and I left it charge over night. It's doing great now.
Get stronger adapter and good cable from a friend or family member and leave it charging for long time.
If you're not lucky you may have to change your battery
05-18-2020 11:04 PM
I have been doing that for three days Do you think my charger is just kaput
05-18-2020 10:50 PM
@stjosephs49 I had that happen with a tablet. The battery suddenly could hold a charge. Stay safe.
05-18-2020 10:47 PM
@stjosephs49 Recharge your phone for 20 minutes and try again.
05-18-2020 10:47 PM - edited 05-18-2020 10:47 PM
What is the model and make of the phone. By chance can you get a screen print of the issue?
05-18-2020 10:46 PM
This happens when it is plugged in also. It shows the fifth symbol above
05-18-2020 10:43 PM - edited 05-18-2020 10:44 PM
@stjosephs49 wrote:When I turn my phone on the warning symbol comes up and then the phone goes off again
What type of warning symbol is it? Does it say anything? This sounds like your phone battery could be on an empty charge.
