08-06-2019 04:25 PM - edited 01-05-2022 06:17 AM
08-06-2019 05:48 PM
@Username1234567 wrote:How do I unlock a phone with public mobile?
@Username1234567 What type of a phone is it? If your phone is locked to the previous provider. You must get the Network Unlock PUK code from your previous provider. If it's an iPhone then the provider will unlock it without the need for a code.If your phone is a Samsung you might be able to get an unlock code from the Samsung website via a chat
To start a live chat session from Samsung's Contact Us page:
http://www.samsung.com/ca/info/contactus.html?CID=AFL-hq-mul-0813-11000170.
Hope this helps!
08-06-2019 04:30 PM
If it is your sim card's security PIN that you've entered numerous times incorectly, that would be why would need the sim card's PUK. The only way to get that is to send a private message to a Moderator. Click here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-06-2019 04:30 PM
You need to go to your old service pervider they can unlock your phone for you or there are lots of websites that unlock phnes
