Phone ok on public mobile
vicki3
R there any flip phones that will work on this network?
9 REPLIES 9
@vicki3 wrote:
thanks for all responses wrote down suggestions and do research thanks again
Members are happy to have been able to help. I have changed the solution as members shouldn't be giving them to themselves.
vicki3
TheGx
@vicki3 :Did any of the above posted replies to this thread you created answer your question? You should follow up with everyone here and choose one of the above posted replies as your accepted solution, to do so click the accepted solution button above the post that helped you most - this will mark this thread you created as solved, and will help others who have similar questions.
@Anonymous wrote:
Pretty much any new phone you can buy in a retail outlet would be compatible. Why would they take up space in their store for something no one could use locally.
Good point that is why an online search may offer the sections.
https://www.bestbuy.ca/en-ca/search?search=flip+phone
@vicki3  2 on the Koodo site: https://www.koodomobile.com/prepaid-phones?INTCMP=KMNew_NavMenu_Shop_PrepaidPhones
HALIMACS
Hi @vicki3
Here's one thing you could try - if there's a used one you wanna test, simply use a friends/family member's Public Mobile SIM in it to see if you can use the phone's calling & texting features.
Data is likely hit or miss with these items - so might be best for a $15 plan with Public Mobile.
@vicki3
I started out with an Alcatel A392 flip phone and still use it as a back up phone. Check compatibility on  https://willmyphonework.net/
NDesai
@vicki3 Only if they are compatible with the 3G/HSPA network bands. PM does not support 2G bands so majority of flip phones wont work.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
