10-05-2015 09:52 AM - edited 01-04-2022 12:46 PM
Hi There,
I am new to Public Mobile and was looking to order a SIM card and create an account. However, I was told my Phone number was invalid or account already created.
How do I go about creating an account?
Thank you
05-05-2019 10:27 PM
Look at top of page and click on Community...scroll down until you see a topic section you can start a thread in. Good luck and welcome to Public Mobile.
05-05-2019 10:25 PM
@wfendricthis thread you're working in is several years old ! For maximum coverage you should start a new thread. Also...you don't want your private info for all to see as this is a public forum. Use the 3 dots in top right hand side of page to edit that out...and start a new thread.
05-05-2019 10:20 PM - edited 05-05-2019 10:27 PM
@imm1304 wrote:Hi @Unit91,
First you should start here: http://store.publicmobile.ca/
Order the sim, it will ask you to create a new account. This is not your public mobile account, this is just for ordering sim card. So, create this myshopify account and order your sim.
Next, when your sim arrives by mail, head over to https://activate.publicmobile.ca/ and follow all the steps to register your sim card and select phone number or port your current number etc. As part of activation, you will creat your new self-serve account. This self-serve account is where you will have control over your plans, payment etc.
Keep in mind that this Community account where you are posting from is separate from the other two accounts I mentioned above. I know, many people have already requested a single sign-on and Public Mobile may do it in future. But, for now, this is how it is. Let us know if you have any questions.
10-05-2015 08:03 PM
Hi @Unit91, there are 3 accounts for the same email with Public Mobile. One to order the SIM card. One when you activated your SIM, and the final one for this forum. As @imm1304 suggested, you are likely to use the email account to order the SIM card to signon, without the activation (or activate with a different email address) and encountered this message. If you have the activation, please check the email confrmation on the plan you have selected. If you do not, please start the activation process as @imm1304 suggested.
10-05-2015 04:51 PM
10-05-2015 04:46 PM
A couple of thoughts in addition to @imm1304's:
- suggest you read We’re sorry, we’re experiencing some issues and Risk Free Activation - costs $10
- be sure your phone is compatible with PM's network: Phones & Hardware
- although it is buried in one of the threads, if you are a Koodo/Telus or PC Mobile customer DO NOT port your number immediately, rather get your SIM & account activated with a temporary number.
10-05-2015 09:59 AM
Hi @Unit91,
