08-15-2019 01:10 PM - edited 01-05-2022 06:26 AM
Hi can any one tell me if the Alcatel Tetra, OT-5041C, 5.0", 16GB ROM, 2GB RAM,, Android 8.1 Oreo, 4G LTE is compatible with Public Mobile?
Thank you in advance
08-17-2019 11:00 AM
@Anonymous wrote:
@jor123 wrote:
@Anonymous wrote:
@nunomarie wrote:Hi can any one tell me if the Alcatel Tetra, OT-5041C, 5.0", 16GB ROM, 2GB RAM,, Android 8.1 Oreo, 4G LTE is compatible with Public Mobile?
That phone will be fine.
There have been reports of problems setting up data with 8.1 in general but maybe not this specific phone. There are workarounds though.
The issue with Rogers etc is that they still use the old 2G GSM. That will be getting phased out next year iirc.
As long as a phone supports the UMTS and LTE bands though Rogers' legacy GSM network still being in operation shouldn't matter.
Yes of course. I was addressing other posts talking about Rogers. I guess I could have been clearer in saying "still use the old" to mean that an old phone that worked there might not work here. Or even a newer phone that is GSM only. The phone in question is a newer modern phone being sold in Canada.
Makes sense, yeah.
08-17-2019 11:00 AM - edited 08-17-2019 11:00 AM
Yes of course. I was addressing other posts talking about Rogers. I guess I could have been clearer in saying "still use the old" to mean that an old phone that worked there might not work here. Or even a newer phone that is GSM only bought elsewhere. The phone in question is a newer modern phone being sold in Canada.
08-17-2019 10:51 AM
08-17-2019 10:48 AM
08-17-2019 09:46 AM
Yup, everyone's moved off of CDMA technologies now. Thankfully..
08-17-2019 09:44 AM
Any unlocked LTE phone should work. PM is owned by Telus and therefore useses the same towers and technology. They also share towers with bell.
So basically if your phone works on Telus, Koodo, bell, virgin it'll work with PM. Rogers and Fido use a different technology so if it's one of theirs that would need to be looked into.
Rogers/Fido use the same bands don't they? The only issue would be whether or not the phone is unlocked to accept a telus sim card?
I stand corrected. Seems they use a mix of LTE and UMTS these days.
08-17-2019 09:44 AM
I'm not sure what frequency bands they use, but Rogers and Fido use something different than LTE. Can't remember what it is off the top of my head. Thing is it's not a technology specific to Rogers just as LTE isn't specific to bell. Most phones can handle either one.
Rogers still uses LTE, and UMTS/HSPA like TELUS does. The only difference was back in the CDMA days where Bell and TELUS phones were totally incompatible with Rogers' GSM/UMTS devices.
08-17-2019 09:41 AM
08-17-2019 09:39 AM
Since it's running Android 8.1, the ability to add APN settings could be a factor. I have not tried this specific phone model.
Having used 8.1 on my previous phone, I can say first hand that you can change the APN settings. Same goes for Android 9. However, I found that with both 8.1 and 9 it picked up on its own without having to put any settings in.
The APN settings are still there and aren't going anywhere.
08-17-2019 09:37 AM
08-17-2019 09:36 AM
08-15-2019 02:43 PM
08-15-2019 01:26 PM
@nunomarie Yes it will work. The phone has HSPA/UMTS 850/1900/2100 4G LTE 2/4/5/12;Would have been nice to have band 7 for LTE but will still work.
08-15-2019 01:22 PM
Check the phone specs. Public Mobile uses the following frequency bands: 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS). HSPA: 850 MHz, 1900 MHz (UMTS). Please note that this information is indicative only. Your phone's compatibility with our 4G or 4G LTE networks is based on the radio frequencies of your phone. Public Mobile does not guarantee that your phone will work on our mobile network.
08-15-2019 01:16 PM
As @GR mentioned, https://willmyphonework.net/ is your best source for compatibility. The PM checker is not reliable.
08-15-2019 01:12 PM
Check willmyphonework.net
