Reply
Highlighted
Phone compatibility
Hello I have an LG stylo 3 plus phone.  Will I be able to use it with Public Mobile?  Thanks.
Highlighted
Re: Phone compatibility
@dji1  You can check the compatibility on the following Get Started page:  https://www.publicmobile.ca/en/bc/get-started
Highlighted
Thanks for the quick response, the stylo 2 plus is shown in the list.  I was hoping that someone with a stylo 3 has had success on public mobile.
Highlighted
@dji1If the phone has been working in Canada.. and it is unlocked it will most likely work with Public Mobile (basically the Telus network).
Highlighted
Awesome, thanks for the response
