Phone compatibility
Gen21
Hello,
Could you please let me know if Alcatel 1X or Alcatel 3V is compatible with your network?
I could not find them in the dropdown list of Alcatel phones.
Thanks,
Gen21
7 REPLIES 7
Gen21
Hi everyone,
Thanks for the useful hints. I bought Alcatel 1X and if works perfectly with Public mobile sim card.
Cheers,
@cavemantoronto wrote:
People are looking all over the place for specs but ignoring the info provided by the maker.
So true!
cavemantoronto
@Gen21 wrote:
Hello,
Thanks,
Gen21
https://ca.alcatelmobile.com/alcatel3v/
  • GSM: B2/3/5/8
  • 3G/4G/LTE
  • UMTS: B1/2/4/5
  • 4G LTE: B1/2/3/4/5/7/8/12/13/17/28
  • MFBI(B17 compatible)
https://ca.alcatelmobile.com/alcatel1x/
CONNECTIVITY
  • GSM: 850/900/1800/1900
  • 3G/4G LTE
  • UMTS: B1/2/4/5/8
  • VoLTE: T-Mobile only
  • Wi-Fi Specs: 802.11 b/g/n
  • Bluetooth: V4.2
  • Next Radio
  • USB Type: Micro
  • SIM Type: Nano 4FF
If you get the Canadian model, you are good.  People are looking all over the place for specs but ignoring the info provided by the maker.
@Gen21
Both phones should work with Public Mobile as stated above.
https://www.gsmarena.com/alcatel_1x-9086.php
https://www.gsmarena.com/alcatel_3v-9004.php
Both phones have the minimum
HSDPA 850/1900
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
hycm53
@Gen21 wrote:
Hello,
Thanks,
Gen21
According this website Alcatel 1X or Alcatel 3V is compatible with PM:
https://www.kimovil.com/en/frequency-checker/CA
Roger3
Friend of mine uses Alcatel 1X and she is happy with the device. Good luck.
hairbag1
@Gen21 wrote:
Hello,
Thanks,
Gen21
Looks like the Alcatel 1X & 3V should work ok.
