Reply
laurenluo
Phone automatic make call to a number to use up minutes
I checked my usage history and find there are many times outgoing call to a number 3065804001, that used up my minutes. It is like a hidden hand to use my phone. Each time it lasts only few seconds, less than 10 second. Is there someone has this experience? And who made this bug?
Accepted Solutions
Re: Phone automatic make call to a number to use up minutes
This is a voicemail number.  I'm uncertain if this is a retrieval or deposit number.  Outgoing calls shown going to this number could be people calling you being directed to your voice messaging system.  Those types of calls are not supposed to count as usages against your 50 minutes.
If you call with your cell phone to check your voice messages, these minutes should/do count.
All Replies
stonechucker
This is a forwarded call that you didn’t answer, or didn’t ring, being sent to your voicemail. You will not incur a charge for this,
Alex888
I believe that is the voice mail number, checking your voice mail does use minutes.
If it's not voicemail it could be an app that you have given permission to monitor/make calls.
z10user4
The usage screen will show all calls happening in or out including call forwarding which voicemail uses. If you're on the $10 plan then only the front overview count matters. And as mentioned...people leaving messages don't count.
Lieux
But if you want to check your vocal message you can use your home phone with this number and it will not count on your 50 minutes @laurenluo
Doonerz
Simply call your mobile number from your landline and press star(*) and they prompt you to input PIN number. Retrieve voicemail messages without counting towards your 50 minutes.
Rao
My minutes are being used by this phone number 6045804001 as well, I have already lost about 30 minutes . Please help me to stop this from my phone
RossN
@Rao  hi that is you checking your voicemail you must be on a limited minute plan you can check your voicemail from a landline or other phone for free
Rao
Is there anyway I can cancel my voice mail, I really don't need that
