04-07-2021 09:48 PM - edited 01-06-2022 01:42 AM
04-07-2021 09:52 PM
Type "need PUK" in the small, white bubble to the bottom right and follow the precise instructions.
04-07-2021 09:51 PM
@Judychan wrote:I urgently need a PUK Code to unlock my SIM card
Can you report back the exact message that your phone is giving you?
Sometimes, a phone will ask for a "SIM Network Unlock PUK". That actually means that your phone is unlocked. For that, you'll have to contact the original carrier that the phone is locked to.
For the security PUK of your SIM card, you need to open a ticket by going to: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
04-07-2021 09:49 PM
Find you PUK: https://www.publicmobile.ca/en/on/get-help/articles/where-to-find-your-puk
SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI (dial *#06# to get it) and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
