PM not affected by Oneplus July/Aug 2021 update
lamyamyamy
I just left koodo with data and mms issues. Phone wasn't allowing you to edit one of the APN fields.
Anyway, if you're looking at joining PM your stuff will be fully functional. At least mine is.
lamyamyamy
Yes. My oneplus nord 10 5g is working on this network.
@Anonymous   AI only catch specific phases and try to dump something..  But I like Google.. at least when I ask tough questions to my Google Home, instead of given me nonsense, Google would answer me directly and honestly  "Sorry, I can't help with that"
 @lamyamyamy : No one understands why the whole kitchen sink was posted.
Glad to hear it's all good. Some phones do have APN issues here too though.
update @lamyamyamy
do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
How to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  HERE
click HERE
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  HERE
and go Changing APN Settings On Android device
click HERE
Ensure you have the correct APN settings by visiting HERE.
for iphone  go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is go through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your DATA is on.
Good Luck
@lamyamyamy  So, you are good after coming to PM?
