09-05-2019 08:03 AM - edited 01-05-2022 06:52 AM
My main problem is receiving group txts from both people using Iphones and Androids. Never used to be a problem, but now I just don't receive a single one. Also the occasional direct txt msg from one person to me isn't working. Any suggestions? Thanks
09-14-2019 03:26 PM - edited 09-15-2019 05:08 PM
@Yanwj Just in case you are still having problems try the following:
09-05-2019 08:35 AM
@Yanwj, what phone and texting app are you using? I sense that is the likely source of the problem. If the texting feature in your plan works even once, there is no reason for the system to selectively not work every time. If you want to rule out any possibilities of account related issues, you can always ask the modertor team to give the account a reset. The moderator team can be reached via private message using using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage. The guided process will facilitate documentation of the issue or concern and the required resolution. This will speed up problem resolution significantly. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions.
09-05-2019 08:33 AM
Group texts require MMS, so check and see if your data is on when you are, or more correctly aren't receiving these texts.
Also, you can check your MMS setting in your APN settings:
These are mine:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
