07-19-2020 04:31 PM - edited 01-05-2022 12:10 PM
Hi, Since sometime overnight Thursday or Friday morning, I've not been able to receive calls or texts. Can call and send just fine. I've read the boards and tried everything that was suggested. My bill is paid, lol , so I know it's not that. I've even removed the sim, but cannot remove battery as it is internal. Samsung Galaxy S6. Thanks for any help.
07-19-2020 06:45 PM
@Leigh01 wrote:Hi, thanks very much. Switching sims back and forth seems to have it back now. Thanks again. Excellent job by the community.
Thank you for report back your success.
Continue to enjoy your saving with PM.
07-19-2020 05:27 PM
07-19-2020 05:04 PM
1. What plan do you have?
If you have the $10 plan with 50 minutes + 50 outgoing texts you may have used all your minutes and texts for the current cycle.
2. To eliminate hardware issue, try your SIM card with another phone. Use another SIM on your phone. Please report result.
07-19-2020 04:35 PM - edited 07-19-2020 04:36 PM
@Leigh01 check to see if DND is enabled. Reset your network settings and restart your phone if it doesn't automatically do so.
Stay safe.
07-19-2020 04:35 PM
@Leigh01 can you check if do not disturb is enabled?
try resetting your network settings
1. Open Settings>General Management>Reset
2. Tap Reset Network Settings>Tap Reset Settings
If prompted enter your pin, passcode
3. Tap Reset Settings 1 more time to confirm
4. Restart
07-19-2020 04:34 PM
Try cycling Airplane mode on/off. See if that makes any difference.
