Reply
Highlighted
Re: No data
@Lrozenberg88 wrote:
I did a network reset but it didnt solve a problem. I didnt do factory reset yet. I’m little aprehensive doing that. It might  not help and i might loose some data. There is no guarantee that it will help right?
Please confirm that you still have data to use. Log into My Account / My Data & Add-ons to see how much has been consumed...if you see none, that's indicating that its been used up until next renewal. You can also consider a data add-on (1GB / $15) to carry you over if your data has been exhausted already.
Highlighted
Re: No data
Hi, just need to top up my data to push me up to date of payment of my plan because mine it’s finished.thanks
Highlighted
Re: No data
@Lrozenberg88 did you re enter @RossN 's APN settings above  after the network reset? Thanks.  Enable data after and try sending an mms message.
Highlighted
Re: No data
@MUSA then go into add ons and add some data. You first need to add funds to your account then you can complete the add on process. So if you want 1G add 15.00 to your account by making a one time payment.
Then go to addons and add the 1G, it will apply immediately and you will be on your way.
But if you need much more then that it may be cost effective to change your plan. how mich longer do you have until renewal?
Highlighted
Re: No data
Factory resetting of the phone worked. Thank you.
Highlighted
Re: No data
@Lrozenberg88 awesome great to hear!
