08-15-2019 10:24 AM - edited 01-05-2022 06:25 AM
Lately, I do not have service, no data. Call/text work. Please check it and confirm. Thank you.
08-15-2019 04:46 PM
@SvetlanaV wrote:Yes, I checked it. Unfortunately, its not easy to find right information ( any data left) there. Thanks!
@SvetlanaV this likely means you've used up all your data for your current cycle. If you don't see a data amount listed on the "My Data and Add-Ons" section of the Overview page (the one you end up on after signing into your account), then that means you have used all of your data for the current cycle. This would also explain why your data stopped working!
08-15-2019 04:05 PM
@SvetlanaV hi have you gone into your self serve account your data usage is in there under data and add ons if none is showing than it is all used up for this cycle can you verify? what plan are you on did your cycle just renwew?
08-15-2019 04:00 PM
08-15-2019 03:55 PM
Thnak you your information! I called 611 from my phone and confirm payment. Yes, it is set pu as AutoPay why my account has been suspended? I did a couple time additional payments and add-ons. Please check all my payments and re-activate account. Please confirm.
Thank you for your help!
08-15-2019 11:18 AM
@SvetlanaV wrote:Lately, I do not have service, no data. Call/text work. Please check it and confirm. Thank you.
@SvetlanaV If your plan renewal date was the 12th or 13th of this month and you are using AutoPay there is a chance that the payment did not go through and your account has been suspended. To verify call 611 from your phone. If it says your account is suspended then you need to manually add the funds and re-activate it.
08-15-2019 10:50 AM
To fix your issue, you need to contact the moderators at Public Mobile. This is the link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
I am not a public mobile employee like most people that post in this forum.
08-15-2019 10:27 AM
@SvetlanaV Hi you are on a public forum with customers like you so we cant check it for you, what plan are you on have you checked your self serve account do you have any data left?
08-15-2019 10:26 AM
Which plan are you do you have? Did data work before?
In your self service account, do you see your data add on in the overview page? If you do not see the data add on, it might mean that you ran out of data for this 30 day cycle.
08-15-2019 10:25 AM
@SvetlanaV- You should start by checking your self serve portal. Does it show that you have an active plan? When was your last renewal date?
