04-16-2019 12:00 PM - edited 01-05-2022 04:25 AM
My phone loads Telus APN instead of PM APN. So data doesn't work .Android 8.1 APN is not modifiable and cannot add a new one. Help?
04-23-2019 10:06 AM
Thanks, but still not able to add or modify APN with that app. Android is becoming big brother, what happened to open source software?
04-16-2019 02:52 PM
@Anonymous wrote:
@computergeek541 wrote:(moved to Phones & Hardware by computergeek541)
You've skipped some posts. I know I replied to that OP. I think wetcoaster replied first.
There were 2 different threads on the topic. They've been merged now.
04-16-2019 02:47 PM - edited 04-16-2019 02:48 PM
04-16-2019 02:43 PM
04-16-2019 12:47 PM
@hycm53 wrote:
@Elliotapplebaum wrote:My phone loads Telus APN instead of PM APN. So data doesn't work .Android 8.1 APN is not modifiable and cannot add a new one. Help?
You need download this app:
It’s work for Asus Zonefon 4 Max that I’m using right now.
After installed app, follow the instructions to add APN. Follow this link to edit APN:
04-16-2019 12:34 PM
04-16-2019 12:18 PM
@wetcoaster wrote:Thanks for proofreading, @Anonymous. Will edit link for future reference.
lol And I said "It's". What it's? Anyway yes the RFD post.
Also for the OP another SIM that would apparently work is Roam Mobility.
04-16-2019 12:15 PM
04-16-2019 12:11 PM - edited 04-16-2019 12:12 PM
It's been updated to here.
Seems pretty simple actually. Download. Copy to phone. Install. Fiddle some permissions. Add APN.
Be sure to have the right APN info once you have the app.
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
04-16-2019 12:08 PM - edited 04-16-2019 12:14 PM
Edit:
Saw the double post, with the correct answers in the comments.
04-16-2019 12:05 PM - edited 04-16-2019 12:18 PM
@Elliotapplebaum wrote:My phone loaded the Telus APN instead of public mobiles. And having android 8.1 it is not changeable. What can I do?
The inability to add a new APN or modifying an existing one is a known Android 8.1 problem.
Other people have had success putting a Freedom SIM in, which seemed to have allowed them to add a new APN, fill in Public Mobile settings, reboot. Put Public Mobile SIM in.
(I think... For me playing with an active SpeakOut SIM eventually populated the Public Mobile APN settings, but I didn't write down the exact steps, sorry.) YMMV.
The relevant post https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Android-8-1-APN-settings/m-p/289974/h... in the big Android 8.1 APN thread: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Android-8-1-APN-settings/td-p/241715
Another way to deal with it: https://forums.redflagdeals.com/solved-fido-apn-miui-10-cant-add-apn-2239645/2/#p30756342 (Disclaimer: I have not tried this myself. But have seen several reports that it works.)
Edited link, as per @Anonymous 's correction below.
04-16-2019 11:47 AM
