My Samsung S6 won't MMS
BOBBYBUTLER
 Is there anyone that can help me get my S6 Samsung to send picture messages? I seem to put all of the proper server stuff in but it still doesn't work any tips out there?
Salmonlips
thanks this was very helpful for myself as well!  i thought i was just having problems with mms not working because i  was roaming and had spotty connection.   nope!
BOBBYBUTLER
Finally I have a normal phone thanks.
RobertQc
@BOBBYBUTLER Have you properly configured your APN? The settings to be able to send pictures (MMS) and navigate on internet (DATA). Your "Mobile Data" needs to be activated. You can go here https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-up-Data-APN-on-your-phone/ta-p...
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Name: Public Mobile / Mobile Internet
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
Authentication type: Not set
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Once you veritify your APN there are some other things we can try if you still have difficulty.
