Reply
mariesel07
Motorola G8 Play
Can I use a Motrola G8 Play to get activated. It is not within the choices on the Public Mobile website.
Tags (1)
Accepted Solutions
Re: Motorola G8 Play
Hi @mariesel07
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Motorola G8 Play:
NETWORK
TechnologyGSM / HSPA / LTE
2G bandsGSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
3G bandsHSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G bands1, 2, 3, 4, 5, 7, 8, 28, 66 - LATAM
SpeedHSPA 42.2/5.76 Mbps, LTE-A
Yes 🙂
All Replies
Jb456
Yes you can!
Don't forget to use a referral code for a $10 signup bonus.
Welcome to Public Mobile 🙂
Hi @mariesel07
Motorola G8 Play:
NETWORK
Yes 🙂
hairbag1
Make sure the phone is unlocked and not reported as stolen.
gblackma
@mariesel07 according to this site https://www.gsmarena.com/motorola_moto_g8_play-9918.php its 100% compatible has both the required 3g and 4g LTE bands.  Welcome to PM. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Note your previous providers account must be active to port your number.  The port will close it once its completed.
tblaing
I have an existing account and had to buy a new phone. I can't seem to get my new Motorola G8 Power Lite to work with Public Mobile. Can anyone help? Thanks
Triguy
Can you provide more details ?  Are you able to make call and send texts ?  Did you setup the APN settings ?
zblackma
@tblaing did you insert the sim card and restart the Moto G8 play? Do it now, wait 30 seconds and restart it.
tblaing
Yes, I did both of those things.
tblaing
Re: Motorola G8 Power Lite
I can make calls (but the phone says "emergency calls only) and can receive texts. When I try to set up the APN by editing the access point, all of the fields are greyed out and I can't edit them.
