Motorola G7 Play model XT1952-2
Marlon
I was looking to purchase the Motorola G7 Play model XT1952-2 from Amazon but when I use the "Check My Phone" service, that specific model number isn't listed - will this phone work with Public Mobile?
8 REPLIES 8
zero_gravity
I'm using the G7 plus model. It'll work for sure.
Master2000
Motorola G7 Play XT1952-2 will work.
Most towers who has your missing 700MHz will also have other frequency.
https://www.plusmobile.fr/fiches-techniques/motorola/moto-g7-play/xt1952-2/
3G UMTS 850/900/1700/1900/2100
4G LTE B1, B2, B3, B4, B5, B7, B28, B66)
Public Mobile frequency
3G HSPA+ B2(1900), B5(850)
LTE B2 (1900)
LTE B4 (1700/2100 AWS 1)
LTE B5 (850)
LTE B7 (2600)
LTE B12(700)
LTE B13(700)
LTE B17(700)
LTE B29(700)
My Moto X Play works fine and it is 3 1/2 years old now.
Terry
popping
@Marlon
Koodo is selling Motorola G7 Play.  It should work with PM.
https://www.koodomobile.com/phones/motorola-g7-play
Marlon
Thank you! I'll check there 🙂
GR
@Marlon   check it on willmyphonework.net   that ones more accurate!
Triguy
It should work on PM if it works on Freedom.
Dunkman
@Marlon
It should work.
Here are the specs:
https://www.gsmarena.com/motorola_moto_g7_play-9532.php
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
