Reply
Mobile Data not working
I recently bought the Umidigi X (Android) phone off Amazon. I was already a Public Mobile customer before. It allows me to text but not able to use data. I can't change or add a new APN. It says there are 2 Telus APN, even though it's unlocked and using my PM SIM card. It just sits there all grey and unable to add/edit. Is there anything I can do?
Please help
Tags (1)
Re: Mobile Data not working
@awk321 , I am using a Umidigi A5 pro purchased from Amazon recently.  The Public Mobile APN is on file and I did not have to do anything to use data.  I can't imagine they would have the right APN data for Public Mobile and not incorporate the same into all their phones.  This is a dual SIM phone.  Are you able to put the SIM card in slot 1 if you have not done so?  Maybe that might help.  I am certain that the loss of the add APN option was on android 8.1 only.  The Umidigi runs android 9 or 10.
Please help
If the Public Mobile APN isn't there and it doesn't allow you to either edit or add, one way to get around this (I've never tired) is to use either a Roam Mobility or Freedom Mobile sim card.  When that sim card is in the phone, add a Public Mobile APN.
Yeah, I have it in slot 1 and it's running Android 9.0 out of the box. I'm confused about why I can't use data or add a APN?
I hope someone has a solution
Does the Sim have to activate? Or alternatively could I use someone's active card to do it?
Thanks
Thanks
No, the Freedom or Roam sim card doesn't need to be active, although I have no personal experience with this process.
@awk321  First check for and install the latest updates for your phone. Go into the Access Points menu and hit reset to default. Then go into preferred network. Is there a Public Mobile entry? If not create one. Set Network ID to 302220 and network type to 3G/4G. Select the newly network and check the APN is it there? If not, reset to default power down your device remove your sim, wait 15 minutes, insert the sim power up and test to see if data is working.
If it's still not working maybe try a factory reset.
Moderator
Hi awk321,
If you need further help, feel free to submit a ticket through SIMon, our virtual assistant and we will take a look into your situation.
Regards,
Ciprian
PM Mod Team.
@computergeek541 wrote:
Please help
I need to find a phone running on android 8.1 so I can test this out.  I have a few old Wind SIM cards in the shoe box.  I know that carrier phones can have butchered APN configuration files.  Typically, non carrier phones don't have this problem as the APN configuration file is complete with entries for every carrier in the world.
Thanks, I was not aware of this issue beforehand. I hope it works
