MMS
danduf1981
After switching from lucky Mobile I can no longer send or receive MMS. I entered all the correct APN settings and they just fail.
Luddite
@danduf1981 What brought you back from Lucky?
danduf1981
All good now. Just reset network settings. Thanks!!
gblackma
@danduf1981 what's the make and model of your phone?  And if you ported, it can take up to 3 hours to complete.Thanks. Welcome to PM. Stay safe.
@danduf1981
Also make sure that your data is turned on and working properly.
Maybe try a network reset or reboot phone.
[Today's solution highlighted ....... Luddite]
Triguy
Can you post your APN settings ?
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
